Hola tengo un problema con un plugin orden #43281.
ya hice api key de google de hecho antes usaba otro plugin ( pedidos ya ) con esa api key y funcionaba pero con este plugin me da este error
Distance not found in cache, will perform API request.
Request:
Array
[origins] => Colon 582, Godoy cruz, 5501, Argentina
[destinations] => Mendoza, Argentina
[mode] => driving
[avoid] => none
[units] => metric
[sensor] => 0
[region] => ar
Response:
Array
[headers] => Requests_Utility_CaseInsensitiveDictionary Object
[data:protected] => Array
[content-type] => application/json; charset=UTF-8
[date] => Thu, 27 Oct 2022 22:01:05 GMT
[pragma] => no-cache
[expires] => Fri, 01 Jan 1990 00:00:00 GMT
[cache-control] => no-cache, must-revalidate
[vary] => Accept-Language
[content-encoding] => gzip
[server] => mafe
[x-xss-protection] => 0
[x-frame-options] => SAMEORIGIN
[server-timing] => gfet4t7; dur=45
[alt-svc] => h3=":443"; ma=2592000,h3-29=":443"; ma=2592000,h3-Q050=":443"; ma=2592000,h3-Q046=":443"; ma=2592000,h3-Q043=":443"; ma=2592000,quic=":443"; ma=2592000; v=“46,43”
[body] => {
“destination_addresses” : [],
“error_message” : “API keys with referer restrictions cannot be used with this API.”,
“origin_addresses” : [],
“rows” : [],
“status” : “REQUEST_DENIED”
[response] => Array
[code] => 200
[message] => OK
[cookies] => Array
[filename] =>
[http_response] => WP_HTTP_Requests_Response Object
[response:protected] => Requests_Response Object
[body] => {
“rows” : [],
[raw] => HTTP/1.1 200 OK
Content-Type: application/json; charset=UTF-8
Date: Thu, 27 Oct 2022 22:01:05 GMT
Pragma: no-cache
Expires: Fri, 01 Jan 1990 00:00:00 GMT
Cache-Control: no-cache, must-revalidate
Vary: Accept-Language
Content-Encoding: gzip
Server: mafe
X-XSS-Protection: 0
X-Frame-Options: SAMEORIGIN
Server-Timing: gfet4t7; dur=45
Alt-Svc: h3=":443"; ma=2592000,h3-29=":443"; ma=2592000,h3-Q050=":443"; ma=2592000,h3-Q046=":443"; ma=2592000,h3-Q043=":443"; ma=2592000,quic=":443"; ma=2592000; v=“46,43”
Connection: close
Transfer-Encoding: chunked
“rows” : [],
[headers] => Requests_Response_Headers Object
[content-type] => Array
[0] => application/json; charset=UTF-8
[date] => Array
[0] => Thu, 27 Oct 2022 22:01:05 GMT
[pragma] => Array
[0] => no-cache
[expires] => Array
[0] => Fri, 01 Jan 1990 00:00:00 GMT
[cache-control] => Array
[0] => no-cache, must-revalidate
[vary] => Array
[0] => Accept-Language
[content-encoding] => Array
[0] => gzip
[server] => Array
[0] => mafe
[x-xss-protection] => Array
[0] => 0
[x-frame-options] => Array
[0] => SAMEORIGIN
[server-timing] => Array
[0] => gfet4t7; dur=45
[alt-svc] => Array
[0] => h3=":443"; ma=2592000,h3-29=":443"; ma=2592000,h3-Q050=":443"; ma=2592000,h3-Q046=":443"; ma=2592000,h3-Q043=":443"; ma=2592000,quic=":443"; ma=2592000; v="46,43"
[status_code] => 200
[protocol_version] => 1.1
[success] => 1
[redirects] => 0
[url] => https://maps.googleapis.com/maps/api/distancematrix/json?key=AIzaSyAv3LP5iLw_ToCIPt1wczHW9XowuB0UqF8&origins=Colon+582%2C+Godoy+cruz%2C+5501%2C+Argentina&destinations=Mendoza%2C+Argentina&mode=driving&avoid=none&units=metric&sensor=0®ion=ar
[history] => Array
[cookies] => Requests_Cookie_Jar Object
[cookies:protected] => Array
[filename:protected] =>
[data] =>
[headers] =>
[status] =>
