Actualización GenerateBlocks Pro v 2.4.0
Hola podrían actualizar GenerateBlocks Pro a su última versión 2.4.0?
Las últimas actualizaciones traen varios cambios muy buenos
changelog
v 2.4.0
  • Feature: Integrate Conditions system with blocks
  • Feature: Integrate Conditions system with menu items
  • Feature: Add setting toggle to disable Overlay Panel system
  • Tweak: Standardize user capabilities for Conditions system
  • Tweak: Standardize user capabilities for Overlay Panel system
  • Tweak: Add generateblocks_conditions_capability filter
  • Tweak: Add generateblocks_overlays_capability filter
  • Tweak: Improve Overlay Panel frontend caching
  • Tweak: Pause/stop media (videos etc…) in Overlay Panels when they close
  • Tweak: Improve time-based conditions
  • Tweak: Set dropdown menu aria-label in HTML
  • Fix: Sticky header positioning on Android
  • Fix: Full width standard overlay panels
  • Fix: Menu item attributes when using hover
v 2.3.0
  • Feature: Advanced Overlay Panel system
  • Feature: Advanced Conditions system
  • Feature: Create modals
  • Feature: Create mega menus
  • Feature: Create anchored overlays (popovers, etc…)
  • Feature: Create off-canvas panels
  • Feature: Allow pasting full HTML attributes (name: value) into HTML attribute control
  • Tweak: Make collections not publicly queryable
  • Tweak: Don’t add current-menu-item class to opened sub-menu parent item
